[postgis-devel] [PostGIS] #552: [wktraster] ST_SetValue is changing the raster
PostGIS trac at osgeo.org
Wed Jul 28 08:18:06 PDT 2010
 Reporter:  robe       |       Owner:  pracine
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  WKTRaster 0.1.6
Component:  wktraster  |     Version:  1.5.X
 Keywords:             |
Comment(by robe):
 Pierre,
 Sorry had a type in my query -- here is the full
 From help manual
 drop table IF EXISTS dummy_rast;
 CREATE TABLE dummy_rast(rid integer, rast raster);
 INSERT INTO dummy_rast(rid, rast)
 VALUES (1,
 ('01' -- little endian (uint8 ndr)
 '0000' -- version (uint16 0)
 '0000' -- nBands (uint16 0)
 '0000000000000040' -- scaleX (float64 2)
 '0000000000000840' -- scaleY (float64 3)
 '000000000000E03F' -- ipX (float64 0.5)
 '000000000000E03F' -- ipY (float64 0.5)
 '0000000000000000' -- skewX (float64 0)
 '0000000000000000' -- skewY (float64 0)
 '00000000' -- SRID (int32 0)
 '0A00' -- width (uint16 10)
 '1400' -- height (uint16 20)
 )::raster
 -- Raster: 5 x 5 pixels, 3 bands, PT_8BUI pixel type, NODATA = 0
 (2,  ('01000003009A9999999999A93F9A9999999999A9BF000000E02B274A' ||
 '41000000007719564100000000000000000000000000000000FFFFFFFF050005000400FDFEFDFEFEFDFEFEFDF9FAFEF'
 'EFCF9FBFDFEFEFDFCFAFEFEFE04004E627AADD16076B4F9FE6370A9F5FE59637AB0E54F58617087040046566487A1506CA2E3FA5A6CAFFBFE4D566DA4CB3E454C5665')::raster);
  SELECT ST_Value(rast, ST_Point(3427927.75, 5793243.95)) As val FROM
  dummy_rast where rid = 2
 -- returns 253
   SELECT ST_SetValue(rast, ST_Point(3427927.75, 5793243.95),50) As val
 FROM
  dummy_rast where rid = 2;
 -- then run again
 Returns 50.
 This is running on PostgreSQL 9.0 Windows if it makes a difference.
 Haven't tried on 8.4 or 8.3 yet.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/552#comment:3>
