[postgis-devel] [PostGIS] #536: Get rid of the STRICT on geography ST_Intersects
trac at osgeo.org
Tue Jun 1 04:00:59 PDT 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment (by mcayland):
I'm not 100% convinced that this is the right thing to be doing here,
since we only have one reported use case and we don't have a test data set
to play with. In any case, STRICT means that if any input parameter is
NULL then the function can be short-circuited to return NULL which should
help the planner.
In short - without test data and configuration we can work with, I don't
feel we have enough evidence to make this change.
Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/536#comment:1>
