[postgis-devel] Two geometries intersects but intersection is empty
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Fri Jun 4 05:22:42 PDT 2010
+1 for JASPA... :-(
>-----Original Message-----
>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>Sent: 3 juin 2010 15:22
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] Two geometries intersects but intersection is empty
>Ah, yes, PostGIS is using its own code for the intersects test on
>point/polygon... hence the incompatibility. Hm hm.
>P
>On Thu, Jun 3, 2010 at 3:15 PM, Martin Davis <mbdavis at refractions.net> wrote:
>> Thanks.
>> I was actually a bit puzzled by this, since in JTS the intersects and
>> intersection operations use exactly the same code to test whether the point
>> lies inside the polygon. And in fact, when I run this case in JTS, it
>> reports that:
>> intersects = FALSE
>> intersection = EMPTY
>> which is consistent.
>> It seems odd that PostGIS behaves differently. It would be interesting to
>> try this directly in GEOS. Although does PostGIS perhaps not use GEOS for
>> this particular case?
>> Also, the code run in JTS is of fairly recent vintage, so it's possible that
>> GEOS isn't reflecting the most up-to-date algorithm.
>> Martin
>> Pierre Racine wrote:
>>> SELECT st_intersects(geomA, geomB), astext(st_intersection(geomA, geomB))
>>> FROM (SELECT
>>> st_geomfromtext('POINT(-75.5516150170498 49.2824791927083)',4326) AS
>>> geomA,
> geomfromewkb(decode('0103000020e610000001000000050000001c9f33ce69e352c0718f0e9a27a44840e77546654fe352
>c067d2ad7b35a448406cd4767448e352c0fc7fd3a900a44840a1fd63dd62e352c0073d34c8f2a348401c9f33ce69e352c0718f
>0e9a27a44840',
>>> 'hex')) AS geomB
>>> ) foo
>>>> Sent: 3 juin 2010 14:26
>>>> is empty
>>>> FYI: select encode(asbinary(geom),'hex') from ...
>>>> P
>>>> On Thu, Jun 3, 2010 at 2:24 PM, Martin Davis <mbdavis at refractions.net>
>>>> wrote:
>>>>> Pierre, can you provide the second geometry in WKBHex? I can't read the
>>>>> string that you provided.
>>>>>> Here is the case:
>>>>>> geomB))
>>>>>> FROM (SELECT
>>>>>> AS
>>>>>> geomA,
>>>>>> geomfromewkb(E'\\001\\003\\000\\000
>\\346\\020\\000\\000\\001\\000\\000\\000\\005\\000\\000\\000\\034\\2373\\316i\\343R\\300q\\217\\016\\2
>32\'\\244H@\\347uFeO\\343R\\300g\\322\\255{5\\244H at l\\324vtH\\343R\\300\\374\\177\\323\\251\\000\\244H
>@\\241\\375c\\335b\\343R\\300\\007=4\\310\\362\\243H@\\034\\2373\\316i\\343R\\300q\\217\\016\\232\'\\2
>>>> 44H@')
>>>>>> AS geomB
>>>>>> ) foo
>>>>>> Sorry I can't provide it as wkt as the wkt version return the expected
>>>>>> result (and the wkb version does not (before I read Paul's last FAQ)).
>>>>>> Pierre
>>>>>>> bounces at postgis.refractions.net] On Behalf Of Martin Davis
>>>>>>> Sent: 3 juin 2010 12:15
>>>>>>> intersection
>>>>>>> is empty
>>>>>>> Can you post the case?
>>>>>>> This can happen because the intersects predicate test is more accurate
>>>>>>> than the intersection computation. (Technically speaking, it's
>>>>>>> possible
>>>>>>> to detect that two segments intersect, but be unable to compute an
>>>>>>> accurate point that represents the intersection).
>>>>>>>> Hi,
>>>>>>>> Is it possible that st_intersects returns true on two geometries but
>>>>>>>> their st_intersection returns
>>>>>>> "GEOMETRYCOLLECTION EMPTY"?
>>>>>>>> I have a nice case here...
>>>>>>>> Pierre
>>>>>>>> _______________________________________________
>>>>>>>> postgis-devel mailing list
>>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>>>>> Martin Davis
>>>>>>> Senior Technical Architect
>>>>>>> Refractions Research, Inc.
>>>>>>> (250) 383-3022
>>>>> Martin Davis
>>>>> (250) 383-3022
>> Martin Davis
>> (250) 383-3022
