[postgis-devel] [PostGIS] #502: [wktraster] Optimize ST_Intersection
trac at osgeo.org
Mon Jun 7 13:51:42 PDT 2010
Reporter: pracine | Owner: jorgearevalo
Type: defect | Status: reopened
Priority: medium | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Resolution: | Keywords:
Changes (by pracine):
* summary: [wktraster] Optimize ST_Intersection when the geometry is a
point => [wktraster] Optimize ST_Intersection
Old description:
> It might be much quicker to provide the value associated with a pixel
> intersecting with a point geometry when using ST_Intersection() by
> accessing the pixel value with ST_Value instead of vectorizing the whole
> tile. This, obviously, do not work when the intersecting geometry is a
> polygon. In this case we have to vectorize the complete raster tile.
New description:
tile. We have first to fix st_value(rast, geom) so it behave exactly as
st_intersect on edge of raster and pixels.
This, obviously, do not work when the intersecting geometry is a line or a
polygon. In this case we should try to vectorize only the intersecting
part of the raster tile.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/502#comment:3>
