[postgis-devel] [PostGIS] #538: Problem with rendering PostgreSQL 9.0 beta ST_AsBinary
PostGIS trac at osgeo.org
Tue Jun 8 01:41:00 PDT 2010
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.2
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  postgresql9.0 windows
Comment (by mcayland):
 Well, it's useful to know. I'm not convinced that this is our bug to fix
 though - if OpenJump are using their own parser to read escaped WKB, then
 it is their responsibility to update it to support the new format.
 Similarly, if the native PostgreSQL JDBC driver
 (http://jdbc.postgresql.org) hasn't been updated to support the new
 format, then it is the PGDG's bug.
 Does OpenJump come with it's own PostgreSQL JDBC JAR? If so, you may find
 simply switching it for a JAR build built from the latest JDBC driver HEAD
 will fix the issue.
 Mark.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/538#comment:5>
