[postgis-devel] [PostGIS] #540: [wktraster] gdal2wktraster.py -l option is broken
trac at osgeo.org
Wed Jun 9 07:48:03 PDT 2010
Reporter: pracine | Owner: mloskot
Type: defect | Status: new
Priority: high | Milestone: WKTRaster 0.1.6
Component: wktraster | Version: trunk
Keywords: |
If I try:
gdal2wktraster.py -r C:\Temp\test01.bmp -t testmultiimage -s 9102707 -k
200x200 -l 2 > C:\Temp\testmulti5.sql
I get:
File "c:\postgres\bin\gdal2wktraster.py", line 1015, in <module>
main()
File "c:\postgres\bin\gdal2wktraster.py", line 976, in main
wkblify_raster(opts, filename, i)
File "c:\postgres\bin\gdal2wktraster.py", line 921, in wkblify_raster
summary = wkblify_raster_level(options, ds, options.overview_level,
band_range, infile, i)
File "c:\postgres\bin\gdal2wktraster.py", line 888, in
hexwkb += wkblify_band(options, band, level, xoff, yoff,
read_block_size, block_size, infile, b)
File "c:\postgres\bin\gdal2wktraster.py", line 796, in wkblify_band
out_pixels[row] = out_line
ValueError: shape mismatch: objects cannot be broadcast to a single shape
Ticket URL: <http://trac.osgeo.org/postgis/ticket/540>
