[postgis-devel] [PostGIS] #544: alias construct fails in SELECT
trac at osgeo.org
Tue Jun 15 19:41:38 PDT 2010
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Keywords: |
using two queries, with identical constructs other than an alias in the
SELECT list, the one with the alias gives inconsistent results.. maybe the
identifier 'area' is being used for something else?
--- this one works without error
dbb_grid_hack=# select
b.ogc_fid,
st_area( a.wkb_geometry) as area,
st_area(a.wkb_geometry)/(150*150) as area_perc,
st_area(b.wkb_geometry) as area_b
from
constrained_sum2 a,
ct_sac_0 b
where
(a.id150=b.id150) order by area desc;
-- this one gives wrong results sometimes
b.ogc_fid,
area/(150*150) as area_perc,
from
constrained_sum2 a,
ct_sac_0 b
where
ogc_fid | area | area_perc | area_b
21061 | 22500 | 1.11713319443597 | 22500
36756 | 22500 | 1 | 22500
98425 | 22500 | 1 | 22500
83585 | 22500 | 1 | 22500
98683 | 22500 | 2.21060802547667 | 22500
101783 | 22500 | 1.21702020789252 | 22500
83590 | 22500 | 1 | 22500
92120 | 22500 | 1 | 22500
5870 | 22500 | 5 | 22500
110706 | 22500 | 2.88152405025164 | 22500
19157 | 22500 | 1.83199074812995 | 22500
17504 | 22500 | 1 | 22500
105455 | 22500 | 2.985409233284 | 22500
28576 | 22500 | 1.10312756123013 | 22500
41484 | 22500 | 1 | 22500
86113 | 22500 | 1 | 22500
80264 | 22500 | 1 | 22500
97363 | 22500 | 3.07222351900736 | 22500
112246 | 22500 | 3 | 22500
114085 | 22500 | 2.3938812451058 | 22500
113627 | 22500 | 3.97366612998115 | 22500
71307 | 22500 | 1.34081633254157 | 22500
98943 | 22500 | 2 | 22500
Ticket URL: <http://trac.osgeo.org/postgis/ticket/544>
