[postgis-devel] ST_GeometrySplit
George Silva
georger.silva at gmail.com
Wed Mar 10 03:51:18 PST 2010
Hello guys,
AFAIK, ArcGIS only handles the first case. One geometry splitting another,
even in multiple pieces, in case of the aforementioned C shape linestring.
We should return multiple parts, as many as necessary: example, imagine
multiple "C" shape linestrings concatenated together:
___a________start
|__ b___
___c___|
|__ d___end
e
In this case we would have 5 parts (I'm not sure if you all can see it...).
Although the splitter line can be as complex as the user wants, it's a
single line.
George
On Wed, Mar 10, 2010 at 7:50 AM, strk <strk at keybit.net> wrote:
> To add more thoughts, there are cases in which also
> a single-segment "blade" against a single linestring
> may return more than 2 parts:
> +--+---2
> 1| |
> +--+---3
> Vertical line above is a single-segment "blade".
> Input is a single C-shaped linestring.
> Numbers represent the components of output.
> --strk;
> On Wed, Mar 10, 2010 at 11:26:34AM +0100, strk wrote:
> > Brain picking you guys about a ST_GeometrySplit.
> > The cases of interest seem to be:
> > - Split polygon by line
> > - Split line by line
> > - Split line by point
> > Initial questions:
> > - Should we allow multi-segment "blade" lines ?
> > (where a single polygon or line might be cut in multiple pieces)
> > - Should we allow multi-component inputs ?
> > (where the "blade" might cut a single component)
> > Both questions are related to the kind of returned output,
> > that is: should output be always composed by 2 parts or
> > possibly multiple parts ?
> > Comments welcome.
> > --strk;
> > () Free GIS & Flash consultant/developer
> > /\ http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
George R. C. Silva
Desenvolvimento em GIS
http://blog.geoprocessamento.net
(34) 9664-3717
(34) 8843-3717
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100310/e3e65f4f/attachment.html>
