[postgis-devel] ST_GeometrySplit
Chris Hodgson chodgson at refractions.net
Wed Mar 10 10:19:45 PST 2010
Isn't this the same as st_difference(A,B), when given any of those pairs
of arguments? Wrap it in an st_dump() if you want to separate the
individual results?
Chris
strk wrote:
> Brain picking you guys about a ST_GeometrySplit.
> The cases of interest seem to be:
>  - Split polygon by line
>  - Split line by line
>  - Split line by point
> Initial questions:
>  - Should we allow multi-segment "blade" lines ?
>    (where a single polygon or line might be cut in multiple pieces)
>  - Should we allow multi-component inputs ?
>    (where the "blade" might cut a single component)
> Both questions are related to the kind of returned output,
> that is: should output be always composed by 2 parts or
> possibly multiple parts ?
> Comments welcome.
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
