[postgis-devel] [PostGIS] #400: ST_SplitGeometry
PostGIS trac at osgeo.org
Thu Mar 11 12:39:52 PST 2010
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  assigned
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Changes (by strk):
  * status:  new => assigned
Comment:
 Again, trying to have trac keep my formatting :/
 - Will split a poly by a line, a line by a line and a line by a point
 - Will always return a COLLECTION of at most 2 elements: first element is
 what is left after the cut, second element is what was cut
 - When you cut a line using a point, what's left is the initial portion of
 the line (from start to point)
 - When you cut a poly or a line using a line what's left is arbitrarly
 taken as the cut-part which goes to the *left* of the cut line. This is
 for assonance with the word "left"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/400#comment:3>
