[postgis-devel] [PostGIS] #465: st_makevalid segfault
trac at osgeo.org
Mon Mar 15 20:00:12 PDT 2010
Reporter: pramsey | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: osx |
In OS/X 10.5, running caseno == 3 result in a backend crash, though not,
curiously before it has a change to return a result...?
1: st_astext = "MULTIPOLYGON(((2 4,2 6,4 4,2 4)),((4 4,6 6,6 4,4
4)))"(typeid = 25, len = -1, typmod = -1, byval = f)
Program received signal EXC_BAD_ACCESS, Could not access memory.
Reason: 13 at address: 0x0000000000000000
0x00000001039b3a74 in geos::geom::GeometryCollection::apply_ro () at
atomicity.h:51
51 { return __sync_fetch_and_add(__mem, __val); }
(gdb) bt
#0 0x00000001039b3a74 in geos::geom::GeometryCollection::apply_ro () at
atomicity.h:51
#1 0x00000001039b3a80 in geos::geom::GeometryCollection::apply_ro () at
atomicity.h:51
#2 0x0000000100746c30 in GEOSGeom_extractUniquePoints_r
(extHandle=0x100604b80, g=0x100604c60) at geos_ts_c.cpp:4784
#3 0x0000000103693919 in lwgeom_make_valid (lwgeom_in=0x100908530) at
lwgeom_geos_clean.c:766
#4 0x0000000103693e00 in ST_MakeValid (fcinfo=0x7fff5fbfe810) at
lwgeom_geos_clean.c:913
#5 0x0000000100111201 in ExecMakeFunctionResultNoSets
(fcache=0x1008f81c8, econtext=0x1008f7c80, isNull=0x7fff5fbfef50 "\006",
isDone=0x7fff5fbfeb51) at execQual.c:1412
#6 0x0000000100111172 in ExecMakeFunctionResultNoSets
(fcache=0x1008f7db0, econtext=0x1008f7c80, isNull=0x1008f9250 "",
isDone=<value temporarily unavailable, due to optimizations>) at
execQual.c:1387
#7 0x000000010010cadf in ExecTargetList [inlined] () at
/Users/pramsey/Code/postgresql-8.3.8/src/backend/executor/execQual.c:4610
#8 0x000000010010cadf in ExecProject (projInfo=<value temporarily
unavailable, due to optimizations>, isDone=0x7fff5fbff0ac) at
execQual.c:4811
#9 0x0000000100113cef in ExecScan (node=0x1008f7b68,
accessMtd=0x100121260 <SeqNext>) at execScan.c:143
#10 0x000000010010c4f2 in ExecProcNode (node=0x1008f7b68) at
execProcnode.c:334
#11 0x000000010010b21c in ExecutePlan [inlined] () at
/Users/pramsey/Code/postgresql-8.3.8/src/backend/executor/execMain.c:1335
#12 0x000000010010b21c in ExecutorRun (queryDesc=<value temporarily
unavailable, due to optimizations>, direction=ForwardScanDirection,
count=0) at execMain.c:270
#13 0x00000001001bee79 in PortalRunSelect (portal=0x1008f5838,
forward=<value temporarily unavailable, due to optimizations>, count=0,
dest=0x1003d24a0) at pquery.c:943
#14 0x00000001001c09af in PortalRun (portal=0x1008f5838,
count=9223372036854775807, isTopLevel=1 '\001', dest=0x1003d24a0,
altdest=0x1003d24a0, completionTag=0x7fff5fbff460 "") at pquery.c:769
#15 0x00000001001bb5ca in exec_simple_query (query_string=0x1008c0438
"select st_astext(st_makevalid(orig)) from clean_cases where caseno =
3;\n") at postgres.c:1004
#16 0x00000001001bc861 in PostgresMain (argc=1, argv=0x1006004f8,
username=0x1006011d0 "pramsey") at postgres.c:3631
#17 0x00000001001317ae in main (argc=3, argv=0x1006004f0) at main.c:186
Current language: auto; currently c++
SQL was
select st_astext(st_makevalid(orig)) from clean_cases where caseno = 3;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/465>
