[postgis-devel] [PostGIS] #466: test_rect_tree_contains_point segfaults
PostGIS trac at osgeo.org
Tue Mar 16 14:31:08 PDT 2010
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.2
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:
Comment (by pramsey):
 There's not much code there... it's like the actual from EWKT process is
 failing? But that implies parser stuff is failing, which implies...?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/466#comment:2>
