[postgis-devel] [PostGIS] #475: ST_Simple should return false with duplicate points
trac at osgeo.org
Wed Mar 31 09:31:59 PDT 2010
Reporter: kneufeld | Owner: pramsey
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
The OGS specs state: ''"has no anomalous geometric points, such as self
intersection or self tangency"'' and ''"is simple if it does not pass
through the same point twice"''. (2.1.5)
The SQL/MM specs state: ''"is not simple if any interior point has the
same location as another interior point or a point on the boundary"''
(4.1.4)
So, by definition then, this should return false.
select st_issimple(
'LINESTRING(0 0, 1 1, 1 1)'::geometry
st_issimple
t
(1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/475>
