[postgis-devel] [PostGIS] #297: [wktraster] Implement ST_DumpAsPolygons function for raster
PostGIS trac at osgeo.org
Mon May 3 12:20:11 PDT 2010
  Reporter:  mloskot    |       Owner:  jorgearevalo
      Type:  task       |      Status:  assigned
  Priority:  high       |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Comment (by robe):
 I would go for it.  libgdal seemed easier to compile than GEOS actually
 and compiles faster. So I don't consider it a major obstacle.
 If you are doing a minimalist compile which is all that is needed to
 enable ST_DumpAsPolygons and I assume the others, I don't see it as a
 major barrier.
 Most windows users will just download binaries anyway as the PostGIS
 compile process under windows is a bare to begin with.  I imagine
 compiling WKT Raster even with GDAL is even easier under Linux, though I
 haven't tried yet.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/297#comment:31>
