[postgis-devel] [PostGIS] #518: Postgres backend terminated by exception 0xC0000005
PostGIS trac at osgeo.org
Fri May 7 10:01:28 PDT 2010
  Reporter:  loldrup   |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  critical  |   Milestone:
 Component:  postgis   |     Version:  1.4.X
Resolution:            |    Keywords:  backend terminated exception
Comment (by pramsey):
 Right, there seems to be a dependency not only on particular data, but
 having them passed into the function in a particular order, which then
 (maybe?) creates a condition where the data is written past the bounds of
 the memory area and, if there are enough other processes running can hit
 something else and cause it to become invalid, which then causes a
 failure. At least, that's the guess. If we could get you to reproduce the
 error on a pgsql  that is compiled with --enable-cassert, we *might* see
 where the initial memory corruption occurs, instead of seeing the effect
 of it later on when the corrupt segment is then picked up by another
 process.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/518#comment:12>
