[postgis-devel] mingw autotools
Paragon Corporation
lr at pcorp.us
Tue May 11 23:54:03 PDT 2010
Paul,
Yes that sounds familiar. Haven't been able to build the GEOS 3.2+ with the
newer MingW (I could build 3.1 with the newer), so I had to scrap my newer
install and revert when started working on 1.5.
Even gdal which WKT Raster relies on technically doesn't support MingW,
though it works with some hacking.
Anyway. For 2.0 I want a clean start and go VS/VS Express all the way.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Tuesday, May 11, 2010 10:13 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] mingw autotools
It got more confusing, unfortunately. I had an older VM configured exactly
to the old wiki page and the autotools there spit out a usable configure. So
the problem (maybe?) is with moving up to the latest minor version of
MingGW? So I don't know what the answer is except that building with MinGW
is impossibly confusing. If VCC can offer a saner build situation it might
be worth the time spent to just suck it up and go to a pure VCC build. Proj
and GEOS already build in VCC as does pgsql so it's just postgis to do...
P.
On Tue, May 11, 2010 at 6:24 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> Which version of GEOS are you configuring?
> Like I mentioned I haven't had problems with GEOS <= 3.2.2 , but the
> 3.3.0 just can't build under mingw. Which I suspect you are running
> into the same issues?
> I think it builds fine under my VS /VS Express environments last I
checked.
> Which of course vastly limits my ability to test anything in the
> PostGIS 2.0 trunk (aside from I have issues - can't build even against
> old GEOS the trunk under mingw)
> Thanks,
> Regina
> Paul Ramsey
> Sent: Tuesday, May 11, 2010 7:40 PM
> Subject: [postgis-devel] mingw autotools
> Winguys and wingals,
> Trying to follow the generic build instructions on the Wiki, I've
> found that I simply cannot use the mingw/msys autotools to generate a
> GEOS configure file. If I generate one on OSX and copy it over I can
> build GEOS, but the mingw tools create a configure which then fails to
> detect int64 (and god knows what else) which leads to various failures.
> I can hack around this limitation as I always have, but I'm wondering
> if there's some unwritten magic you've got going on. I used the
> instructions, but I got no love.
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
