[postgis-devel] [PostGIS] #530: Retrieving and storing Geography column data through JDBC does not work
trac at osgeo.org
Sat May 22 01:35:59 PDT 2010
Reporter: kristof | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Keywords: geography GeometryType java jdbc |
We used the GeometryType Hibernate UserType that gets delivered with
Postgis 1.5.x (java/ejb3) to store and retrieve Geometry column data.
This works fine but unfortunately it does not seem to support the new
Geography data type.
We tried storing Point and LineString Geometry objects (SRID set to 4326)
but we get an exception that a bytea can't be casted to a Geography.
We use the org.postgis.DriverWrapper Driver class name which is supposed
to automatically load support for the spatial types.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/530>
