[postgis-devel] [PostGIS] #534: Provide function to add new geometries to a collection
trac at osgeo.org
Thu May 27 07:24:01 PDT 2010
Reporter: jchamberlain | Owner: robe
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS 1.5.2
Component: postgis | Version: 1.5.X
Resolution: | Keywords:
Comment (by jchamberlain):
I'll give this a shot and see how it works out. Thx
Replying to [comment:2 robe]:
> One problem with ST_Collect is if you are adding a point to a
multipoint, you would end up with a geometry collection.
> You would probably want to combine with ST_CollectionExtract
http://www.postgis.org/documentation/manual-1.5/ST_CollectionExtract.html
> -- adding a point to a multipoint
> SELECT
ST_AsText(ST_CollectionExtract(ST_Collect(ST_GeomFromText('MULTIPOINT(1 2,
3 4)'), ST_GeomFromText('POINT(5 5)')),1));
> -- adding an array of points to a multipoint
> SELECT
ST_AsText(ST_CollectionExtract(ST_Collect(ARRAY[ST_GeomFromText('MULTIPOINT(1
2, 3 4)'), ST_GeomFromText('POINT(5 5)'), ST_GeomFromText('POINT(0 0 )')]
),1));
Ticket URL: <http://trac.osgeo.org/postgis/ticket/534#comment:5>
