[postgis-devel] [PostGIS] #484: [wktraster] rtpostgis.sql.in.c using old style 1.3 syntax and other arcane stuff
trac at osgeo.org
Mon May 31 19:08:41 PDT 2010
stuff
Reporter: robe | Owner: pracine
Type: task | Status: new
Priority: low | Milestone: WKTRaster Future
Component: wktraster | Version: trunk
Resolution: | Keywords:
Comment (by robe):
2) Its a bit easier to read camel case I think and would also match the
documentation which is camel case. In the end it doesn't matter too much
since when it gets into PostgreSQL it all ends up being lowercase by
PostgreSQL.
3) Not all functions need costing. The ones that take a lot of time that
are non-SQL functions should have costing where there are conditions where
they may not need to be run. I'm not sure we have any of those at this
point. Probably best to just wait off on this. For SQL functions --
generally you don't want to cost them since they often get dissolved by
the planner into constituent parts.
5) Yes blindly.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/484#comment:5>
