[postgis-devel] [PostGIS] #659: shp2pgsql crashing when trying to load into geography order sensitive
trac at osgeo.org
Tue Nov 16 00:52:19 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
I have this statement
shp2pgsql -G -g geog data/roadtrl020.shp ch01.roads_geog > roads_geog.sql
works fine with the PostGIS 1.5 shp2pgsql but crashes with my current
build of PostGIS 2.0 shp2pgsql loader. Loading without the -G switch
works fine too in both and shp2pgsql-gui also works fine in both.
Actually loading like this also works:
shp2pgsql -g geog -G data/roadtrl020.shp ch01.roads_geog > roads_geog.sql
So it seems to be sensitive to the order of the arguments
My build is (running on windows 7)
RCSID: $Id: shp2pgsql-core.h 6008 2010-09-22 23:45:35Z mleslie $ RELEASE:
2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
USAGE: shp2pgsql [<options>] <shapefile> [<schema>.]<table>
Ticket URL: <http://trac.osgeo.org/postgis/ticket/659>
