[postgis-devel] [PostGIS] #658: LWGEOM Update on PostGIS 2.0
PostGIS trac at osgeo.org
Thu Nov 18 10:48:05 PST 2010
 Reporter:  colivier       |       Owner:  colivier
     Type:  task           |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  postgis        |     Version:  trunk
 Keywords:  LWGEOM update  |
Comment(by pramsey):
 I'm guessing the code base has changed enough now to invalidate this
 patch. Olivier, I'm tossing big changes through pretty regularly now. In
 order to avoid stomping on each other, I can arrange a period of a couple
 days where I won't make big changes and you can complete and apply the
 patch. The alternative is either you or I getting stuck with a big sandbox
 of changes that won't merge with trunk.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/658#comment:3>
