[postgis-devel] [PostGIS] #662: Make POLYGONM geometry crashes server
trac at osgeo.org
Thu Nov 18 11:23:52 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
No worries. I'd be really disappointed if you managed to pass my battery
of tests unscathed with that many changes you had there. I'd have to
spend more time making them harder to pass. :). I did add some logging
so it logs and times the tests so its a bit easier to compare against past
tests and spot check things that are failing that shouldn't be. Though
even my test has bugs are have to fix.
I'm not sure we want to add more to the make check as opposed to just
having varying degrees of make check. The standard one -- for casual
changes. A more intense one for things that touch a lot of the code base.
FWIW - I can't run make check in 2.0 because I still get that CUnit error.
cu_tester.c:15:19: dlfcn.h: No such file or directory
I thought we had a bug report for that and Nicklas had a patch, but I
can't find that ticket now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/662#comment:2>
