[postgis-devel] [PostGIS] #662: Make POLYGONM geometry crashes server
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Nov 19 01:25:16 PST 2010
Kevin Neufeld wrote:
> On 11/18/2010 11:23 AM, PostGIS wrote:
>> FWIW - I can't run make check in 2.0 because I still get that CUnit
>> error.
>> cu_tester.c:15:19: dlfcn.h: No such file or directory
> Really? The buildbot's regression testing runs clean.
> -- Kevin
It's because dlfcn.h doesn't exist in Windows, and since it's used to
load dynamic libraries I think we decided that it should just simply be
removed.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
