[postgis-devel] [PostGIS] #627: PostGIS/PostgreSQL process terminates on invalid geometry
PostGIS trac at osgeo.org
Mon Nov 22 08:35:04 PST 2010
 Reporter:  hopfgartner  |       Owner:  pramsey
     Type:  defect       |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 1.5.3
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
Comment(by hopfgartner):
 I've tried to dig into this issue and added some debug info to
 postgis-1.5.1/postgis/lwgeom_geos.c, see attached file.
 When I run the query above, I get the following output:
 melzo=# SELECT
 buffer('0101000020E8640000000000000000F8FF000000000000F8FF', 50.0);
 NOTICE:  [lwgparse.c:parse_it:1669] parse_it:
 0101000020E8640000000000000000F8FF000000000000F8FF with parser flags 7
 LINE 1: SELECT buffer('0101000020E8640000000000000000F8FF00000000000...
 NOTICE:  [lwgparse.c:alloc_lwgeom:343] alloc_lwgeom -1
 NOTICE:  [lwgparse.c:alloc_wkb:1658] alloc_wkb
 NOTICE:  [lwgparse.c:parse_wkb:1539] parse_wkb
 NOTICE:  [lwgparse.c:alloc_stack_tuple:432] alloc_stack_tuple: type = 1,
 size = 1
 NOTICE:  [lwgparse.c:alloc_stack_tuple:443] alloc_stack_tuple complete:
 0x1c2212a0
 NOTICE:  [lwgparse.c:check_dims:926] check_dims the_geom.ndims = 2, num =
 2
 NOTICE:  [lwgparse.c:pop:913] pop: type= 1, tuple= 0x1c2212a0
 NOTICE:  [lwgparse.c:make_serialized_lwgeom:1274] make_serialized_lwgeom
 NOTICE:  [lwgeom.c:serialized_lwgeom_from_ewkt:704]
 serialized_lwgeom_from_ewkt with
 NOTICE:  [lwgeom_api.c:lwgeom_getType:853] lwgeom_getType 65
 NOTICE:  [lwgeom.c:lwgeom_deserialize:26] lwgeom_deserialize got 1 - Point
 NOTICE:  [lwpoint.c:lwpoint_deserialize:255] lwpoint_deserialize called
 NOTICE:  [lwpoint.c:lwpoint_deserialize:286] lwpoint_deserialize: input
 has SRID
 NOTICE:  [lwgeom_api.c:pointArray_construct:788] pointArray_construct
 called.
 NOTICE:  [lwgeom_api.c:pointArray_construct:798] pointArray_construct
 returning 0x1c1ddc38
 NOTICE:  [lwgeom.c:lwgeom_serialize_size:67] lwgeom_serialize_size(Point)
 called
 NOTICE:  [lwpoint.c:lwpoint_serialize_size:147] lwpoint_serialize_size
 called
 NOTICE:  [lwpoint.c:lwpoint_serialize_size:154] lwpoint_serialize_size
 returning 21
 NOTICE:  [lwgeom_pg.c:pglwgeom_serialize:159] lwgeom_serialize_size
 returned 21
 NOTICE:  [lwgeom.c:lwgeom_serialize_buf:101] lwgeom_serialize_buf called
 with a Point
 NOTICE:  [lwgeom_api.c:pointArray_ptsize:811] pointArray_ptsize:
 TYPE_NDIMS(pa->dims)=2
 NOTICE:  [lwpoint.c:lwpoint_serialize_buf:58]
 lwpoint_serialize_buf(0x1c21b650, 0x1c21b624) called
 NOTICE:  [lwgeom_pg.c:pglwgeom_serialize:165] pglwgeom_serialize:
 serialized size: 21, computed size: 21
 has SRID
 called.
 returning 0x1c225348
 NOTICE:  [lwgeom_geos.c:LWGEOM2GEOS:2936] LWGEOM2GEOS got a Unknown
 NOTICE:  [lwsegmentize.c:has_arc:55] has_arc called.
 NOTICE:  [lwgeom_api.c:getPoint3dz_p:582] getPoint3dz_p called on array of
 2-dimensions / 1 pts
 NOTICE:  [lwgeom_geos.c:ptarray_to_GEOSCoordSeq:2912] Point: nan,nan,0
 NOTICE:  [lwgeom_geos.c:LWGEOM2GEOS:3026] LWGEOM2GEOS: GEOSGeom: POINT
 (nan nan)
 NOTICE:  [lwgeom_geos.c:buffer:988] before GEOSBufferWithStyle(POINT (nan
 nan), 50.000000, 8, 1, 1, 5.000000)
 server closed the connection unexpectedly
         This probably means the server terminated abnormally
         before or while processing the request.
 The connection to the server was lost. Attempting reset: Failed.
 The problem seems to be in GEOS or how GEOSBufferWithStyle is invoked from
 within PostGIS.
 Peter
Ticket URL: <http://trac.osgeo.org/postgis/ticket/627#comment:1>
