[postgis-devel] WKB types: polyhedral surface, tin, triangle
Paul Ramsey
pramsey at opengeo.org
Wed Oct 6 12:34:37 PDT 2010
On Tue, Oct 5, 2010 at 11:59 PM, Olivier Courtin
<olivier.courtin at oslandia.com> wrote:
> On Oct 6, 2010, at 12:20 AM, Paul Ramsey wrote:
> Paul,
>> I'm working on the new WKB parser/emitters and wondering where I can find
>> the official type numbers for the polyhedral surface, tin, and triangle
>> types? I see you have stubbed them into liblwgeom.h as 13, 14 and 15, but
>> I'd like to see the appropriate specification document on how they are
>> supposed to be structured.
> I use 13,14 and 15 as only internal PostGIS number availables,
Right, but because the old WKB emitter uses the internal numbers as
outputs, they come out with the wrong numbers. I just actually
confirmed this with a little polyhedral geometry test on the new
output functions, in cu_wkb_out.c. The old code uses a type number of
13 while the new code uses a type number of 15.
So... once the code is flipped over, we should have valid ISO-standard
type numbers in the WKB.
P.
> Standards values:
> ISO SQL/MM draft 2009 (5.1.58 p178):
> POLYEHDRALSURFACE 15
> TIN: 16
> TRIANGLE 17
> POLYHEDRALSURFACEZ: 1015
> TINZ: 1016
> TRIANGLEZ: 1017
> POLYHEDRALSURFACEM: 2015
> TINM: 2016
> TRIANGLEM: 2017
> POLYHEDRALSURFACEZM 3015
> TINZM 3016
> TRIANGLEZM 3017
> It's also consistent with OGC SFS 1.2 (06-103r3)
> 8.2.8 p67
> Olivier
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
