[postgis-devel] [PostGIS] #621: Problem with finding intersections with geography types
trac at osgeo.org
Thu Oct 7 01:25:16 PDT 2010
Reporter: infinitynsk | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: |
I have a database with a column of type "geography" that contains
geographic coordinates of points. I query the database which counts
number of points that are contained in a given polygon.
But I encountered with situation when I get that a point isn't
contained in a polygon but it is contained in another polygon that is a
part of the first one.
Point in database:
POINT(147.88594 70.624908)
I performed three queries:
--select number of points which are contained in polygon
--1
SELECT count(*) from geotest
where point && 'srid=4326;polygon((146.25 72.3957, 151.875 72.3957,
151.875 70.6126, 146.25 70.6126, 146.25 72.3957))'::geography
and st_intersects(point, 'srid=4326;polygon((146.25 72.3957, 151.875
72.3957, 151.875 70.6126, 146.25 70.6126, 146.25
72.3957))'::geography);
--select points which are contained in another polygon; the polygon is
--from previous select, what is confirmed by third select
--2
SELECT asewkt(point::geometry) from geotest
where point && 'srid=4326;polygon((146.25 71.5249, 149.0625
71.5246, 149.0625 70.6126, 146.25 70.6126, 146.25
71.5249))'::geography
and st_intersects(point, 'srid=4326;polygon((146.25 71.5249, 149.0625
71.5246, 149.0625 70.6126, 146.25 70.6126, 146.25 71.5249))'::geography);
--3
select st_contains('srid=4326;polygon((146.25 72.3957, 151.875
72.3957, 151.875 70.6126, 146.25 70.6126, 146.25 72.3957))'::geometry,
'srid=4326;polygon((146.25 71.5249, 149.0625 71.5246, 149.0625
70.6126, 146.25 70.6126, 146.25 71.5249))'::geometry);
And I got:
count
0
(1 row)
asewkt
SRID=4326;POINT(147.88594 70.624908)
(1 row)
st_contains
t
(1 row)
I use postgresql 8.4.5 and postgis 1.5.1
Dump of database with this point is in attachment.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/621>
