[postgis-devel] Proposed changes to the rotate family of functionsfor PostGIS 2.0
Paragon Corporation lr at pcorp.us
Wed Oct 13 12:53:22 PDT 2010
Mike,
You are even more draconian than I am :)  I was only proposing dropping 8.3.
Not 8.4 too.  That seems a bit too harsh even for me :)
As far as your proposal of ST_Rotate enhancements, I don't think we have
reached feature freeze yet for PostGIS 2.0 so I for one would be okay with
it.
Have to get Kevin, Paul and Mark's vote on that too.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mike
Toews
Sent: Wednesday, October 13, 2010 1:11 PM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] Proposed changes to the rotate family of
I'd like to make some changes to the rotate family of functions for the 2.0
release. In summary, it's related to
http://postgis.refractions.net/pipermail/postgis-devel/2010-January/008405.h
tml
My changes would include including extending ST_Rotate to allow a custom
origin. Also I'd like to introduce a ST_Rotate3D function to allow more
complicated 3D rotates, which effectively eliminate the need for
ST_Rotate[XYZ] functions (since I'm convinced they are not usable for
day-to-day work). I'd also update docs and test cases related to the
changes. Also, the scope of this work is limited to geometries only (not
rasters).
So my questions: is this too late for the 2.0 release? Should I write up a
RFC to discuss the changes (I noticed there are a few of these in /doc/rfc)?
Would this be welcome/unwelcome?
Also as a comment, I support PostgreSQL 9.0 as the new minimum version for
PostGIS 2.0. There is a growing number of functions that effectively
overload operators, and changes like what I propose only add to the heap.
-Mike
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
