[postgis-devel] [PostGIS] #629: Raster ST_Contains
trac at osgeo.org
Sun Oct 17 05:08:15 PDT 2010
Reporter: andrewsimpson | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis raster | Version: 1.5.X
Keywords: |
Greetings,
I have loaded 1 band 8bit data to a raster table with tile size 500x500,
and am trying to render through MapServer/GDAL.
Some of the tiles render, but most do not.
After turning logging verbose on PostgreSQL I see that GDAL
wktrasterraterband.cpp is calling for data a tile at a time, and many of
the calls are not returning any data.
Below is the metadata for one such tile, and the SQL that GDAL executes.
It appears the ST_Contains thinks some part of the Box2D is outside the
rast.
I modified the wktrasterraterband.cpp IReadBlock function to
buffer(Box2d,-1) and the all the tiles render.
I know this is not a good solution, any information on what I may do to
remedy this would be great.
Thanks,
Drew
PostgreSQL 8.4.4 on i686-redhat-linux-gnu, compiled by GCC gcc (GCC) 4.1.2
20080704 (Red Hat 4.1.2-48), 32-bit
Postgis-1.5.1
WKTRaster-0.1.6d
GDAL-1.7.2
Python-2.7
Proj-4.7.0
Geos-3.2.2
SELECT rid, (md).*, (bmd).*
FROM (SELECT rid, ST_Metadata(rast) AS md,
ST_BandMetadata(rast) AS bmd
FROM psi_tiled where rid in ( 87 )
) foo;
rid | upperleftx | upperlefty | width | height | pixelsizex |
pixelsizey | skewx | skewy | srid | numbands | pixeltype | hasnodatavalue
nodatavalue | isoutdb | path
87 | 504979.725998 | 2929894.254002 | 500 | 500 | 0.1016 |
-0.1016 | 0 | 0 | 26917 | 1 | 8BUI | f |
0 | f |
(1 row)
SELECT rid, rast FROM public.psi_tiled
WHERE _ST_Contains(rast,
ST_SetSRID( ST_MakeBox2D(ST_Point(504979.725998, 2929843.454002),
ST_Point(505030.525998, 2929894.254002)), 26917))
rid | rast
(0 rows)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/629>
