[postgis-devel] Problems with st_crosses postgis version 1.5
David Potts
dave.potts at pinan.co.uk
Mon Oct 18 21:54:44 PDT 2010
Hi
I seem to have a problem with st_crosses function
I have two square grids, each aligned on top of each other, one grid
represents the other sub divided in to 4 quaters. Each quater shares 2
common edges, the other 2 edges are within the square.
I had assumed that something like
select * from buoy_table b,quater_table q where
st_crosses(b.outline_geom,q.outline_geom)
would return every square in the quater grid within the buoy qrid, ie 4
squares from the quater grid to every single square in the buoy qrid
It returns nothing, any suggestions why ?
expressions like st_intersections(st_buffer(q.outline_geom,-1),
s_buffer(b.outline_geom,-0.1)) will give me what I want, ie the 4 quater
squares per parent square but its very slow!
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Any views expressed in this message are those of the individual sender,
except where the sender specifically states them to be the views of the
Pinan Software
