[postgis-devel] [PostGIS] #635: configure ignores --prefix
trac at osgeo.org
Wed Oct 20 08:43:36 PDT 2010
Reporter: marcusbooster | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: build permissions |
uname -a:
Linux myname 2.6.35-22-server #35-Ubuntu SMP Sat Oct 16 22:02:33 UTC 2010
x86_64 GNU/Linux
PostGIS 1.5.2 builds correctly, but fails on 'make install' because of a
permission error after it ignores './configure --prefix=$HOME/local'
PostgreSQL 9 is a Ubuntu package installed system-wide, postgis configure
is using /usr/lib/postgresql/9.0/bin/pg_config
I wish to install postgis locally.
output:
PostGIS was built successfully. Ready to install.
make -C postgis install
make[1]: Entering directory `/home/myname/tmp/postgis-1.5.2/postgis'
/bin/mkdir -p '/usr/lib/postgresql/9.0/lib'
/bin/mkdir -p '/usr/share/postgresql/9.0/contrib/postgis-1.5'
/bin/mkdir: cannot create directory `/usr/share/postgresql/9.0/contrib':
Permission denied
make[1]: *** [installdirs] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/635>
