[postgis-devel] [PostGIS] #625: make clean does not clean raster
trac at osgeo.org
Fri Oct 22 07:23:53 PDT 2010
Reporter: robe | Owner: jorgearevalo
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Changes (by jorgearevalo):
* cc: jorge.arevalo@… (added)
* owner: pramsey => jorgearevalo
* status: new => assigned
Comment:
Hi Paul,
With the last commit (r6095), you should be able to clean raster by make
clean. Specifically, make clean should:[[BR]]
- Delete core objects (raster/rt_core/rt_api.o and
raster/rt_core/librtcore.a)[[BR]]
- Delete SQL objects (raster/rt_pg/rtpostgis.sql.in,
raster/rt_pg/rtpostgis.sql, raster/rt_pg/rt_pg.o)[[BR]]
- Delete test binaries (raster/test/core/testapi,
raster/test/core/testwkb)[[BR]]
- Delete regression test generated
script(raster/test/regress/run_test)[[BR]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/625#comment:1>
