[postgis-devel] [PostGIS] #636: Compile error (lwin_wkt.c)
PostGIS trac at osgeo.org
Fri Oct 22 12:28:45 PDT 2010
  Reporter:  jorgearevalo  |       Owner:  pramsey
      Type:  defect        |      Status:  closed
  Priority:  blocker       |   Milestone:  PostGIS 2.0.0
 Component:  postgis       |     Version:  trunk
Resolution:  fixed         |    Keywords:
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 OK, patch applied at r6100. Note you might need to make clean before you
 make. My test was to rm lwin_wkt_parse.h and that case is not handled, but
 it's a degenerate situation. Das is goot.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/636#comment:7>
