[postgis-devel] [PostGIS] #645: more raster/scripts/plpgsql st_setarray.sql, st_sevalues, st_union
PostGIS trac at osgeo.org
Sat Oct 23 15:54:35 PDT 2010
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 I'm guessing these are still a work in progress since there are several
 things wrong with them
 1)  In st_union you have MapAlgebra4... which doesn't start with ST_ like
 the other functions
 2) You have several places where you have band but don't declare the type
 yielding
 ERROR:  type band does not exist
 3) The st_setarray.sql contains a function called: huh -  ST_SetArea
 4) st_sevalues.sql (should be called st_setvalues)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/645>
