[postgis-devel] [PostGIS] #636: Compile error (lwin_wkt.c)
trac at osgeo.org
Sat Oct 23 16:29:31 PDT 2010
Reporter: jorgearevalo | Owner: pramsey
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment(by robe):
I wouldn't be too upset if it were just MingW, but you have displeased our
butler Hudson as well and he's having trouble sending email (Kevin maybe
you should check on the email issue).
bison -y -o lwin_wkt_parse.c -d lwin_wkt_parse.y
gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes -c -o
lwin_wkt_parse.o lwin_wkt_parse.c
In file included from lwin_wkt_parse.y:16:
lwin_wkt.h:50:54: warning: no newline at end of file
flex -i -o lwin_wkt_lex.c lwin_wkt_lex.l
flex: can't open lwin_wkt_lex.c
make[1]: *** [lwin_wkt_lex.c] Error 1
make[1]: Leaving directory `/var/home/buildbot/opt/hudson/jobs/PostGIS-
trunk-build/workspace/src/liblwgeom'
make: *** [liblwgeom] Error 2
ERROR: Could not connect to SMTP host: 192.168.50.200, port: 25
javax.mail.MessagingException: Could not connect to SMTP host:
192.168.50.200, port: 25;
nested exception is:
java.net.NoRouteToHostException: No route to host
at
com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1282)
at
com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:370)
at javax.mail.Service.connect(Service.java:275)
at javax.mail.Service.connect(Service.java:156)
at javax.mail.Service.connect(Service.java:105)
at javax.mail.Transport.send0(Transport.java:168)
at javax.mail.Transport.send(Transport.java:98)
at hudson.tasks.MailSender.execute(MailSender.java:108)
at hudson.tasks.Mailer.perform(Mailer.java:112)
at
hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
at
hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:601)
at
hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:580)
at
hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:558)
at hudson.model.Build$RunnerImpl.post2(Build.java:158)
at
hudson.model.AbstractBuild$AbstractRunner.post(AbstractBuild.java:528)
at hudson.model.Run.run(Run.java:1264)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at
hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:122)
Caused by: java.net.NoRouteToHostException: No route to host
at java.net.PlainSocketImpl.socketConnect(Native Method)
at
java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:310)
at
java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:176)
at
java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:163)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:381)
at java.net.Socket.connect(Socket.java:537)
at
com.sun.mail.util.SocketFetcher.createSocket(SocketFetcher.java:230)
at
com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:189)
at
com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1250)
... 18 more
Notifying upstream projects of job completion
Finished: FAILURE
Ticket URL: <http://trac.osgeo.org/postgis/ticket/636#comment:15>
