[postgis-devel] [PostGIS] #647: HUdson can't send mail
trac at osgeo.org
Sun Oct 24 11:44:36 PDT 2010
Reporter: robe | Owner: kneufeld
Type: defect | Status: new
Priority: medium | Milestone: Management 1.0
Component: management | Version: trunk
Keywords: |
Kevin,
Thought I better post this as a separate ticket so you get it. Hudson is
having trouble sending email.
Sending e-mails to: kneufeld at refractions.net jorgearevalo at gis4free.org
pramsey at cleverelephant.ca robe.dnd at cityofboston.gov
ERROR: Could not connect to SMTP host: 192.168.50.200, port: 25
javax.mail.MessagingException: Could not connect to SMTP host:
192.168.50.200, port: 25;
nested exception is:
java.net.NoRouteToHostException: No route to host
at
com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1282)
at
com.sun.mail.smtp.SMTPTransport.protocolConnect(SMTPTransport.java:370)
at javax.mail.Service.connect(Service.java:275)
at javax.mail.Service.connect(Service.java:156)
at javax.mail.Service.connect(Service.java:105)
at javax.mail.Transport.send0(Transport.java:168)
at javax.mail.Transport.send(Transport.java:98)
at hudson.tasks.MailSender.execute(MailSender.java:108)
at hudson.tasks.Mailer.perform(Mailer.java:112)
at
hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
at
hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:601)
at
hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:580)
at
hudson.model.AbstractBuild$AbstractRunner.performAllBuildSteps(AbstractBuild.java:558)
at hudson.model.Build$RunnerImpl.post2(Build.java:158)
at
hudson.model.AbstractBuild$AbstractRunner.post(AbstractBuild.java:528)
at hudson.model.Run.run(Run.java:1264)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at
hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:122)
Caused by: java.net.NoRouteToHostException: No route to host
at java.net.PlainSocketImpl.socketConnect(Native Method)
at
java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:310)
at
java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:176)
at
java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:163)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:381)
at java.net.Socket.connect(Socket.java:537)
at
com.sun.mail.util.SocketFetcher.createSocket(SocketFetcher.java:230)
at
com.sun.mail.util.SocketFetcher.getSocket(SocketFetcher.java:189)
at
com.sun.mail.smtp.SMTPTransport.openServer(SMTPTransport.java:1250)
... 18 more
Notifying upstream projects of job completion
Finished: FAILURE
Ticket URL: <http://trac.osgeo.org/postgis/ticket/647>
