[postgis-devel] memory management questions #1
Paul Ramsey pramsey at opengeo.org
Sun Oct 24 15:17:00 PDT 2010
On Sun, Oct 24, 2010 at 2:37 PM, Nicklas Avén
<nicklas.aven at jordogskog.no> wrote:
> I think lwgeom_free and lwgeom_release seems to do much the same thing.
> Why do we have both? When to use which one?
There are serious inconsistencies in our free/release API which you
are seeing. Fundamentally there isn't much difference anymore. An
important thing to understand, though, is that an LWGEOM deserialized
from a database PGLWGEOM will have point arrays with
serialzed_pointlists that back right onto the database memory. Which
means you cannot free those pointlists.
Contrariwise, a geometry you construct yourself from WKT or something,
will have completely free floating serialized_pointlists, which you
should deallocate before leaving.
My hope for 2.0 is to include in the geometry/pointarray 'flags' a
flag that indicates whether the underlying serialized_pointlist arrays
are managed by teh database or by the lwgeom, so that lwgeom_free can
magically "do the right thing".
As it stands now, it's a mess and there is no consistency, and some
code has manually implemented things like freeing right to the bottom
rather than using the API.
>> I found that the bbox was not released when calling lwgeom_free with points.
> For other types there is a check for bbox and they are freed but not for
> points in lwpoint_free.
> Is that for some reason or is it a bug?
Probably a bug, based on the expectation that most point objects won't
have bounding boxes.
> Then I have a third question that maybe wrong time to ask since Paul is
> working on the parser. But I get memory leaks when using lwgeom_from_ewkt
> looking like this:
> ==32144== 37 bytes in 1 blocks are definitely lost in loss record 2 of 3
> ==32144==    at 0x4C274A8: malloc (vg_replace_malloc.c:236)
> ==32144==    by 0x42BB7F: make_serialized_lwgeom (lwgparse.c:1387)
> ==32144==    by 0x42CA2A: parse_it (lwgparse.c:1730)
> ==32144==    by 0x417253: serialized_lwgeom_from_ewkt (lwgeom.c:758)
> ==32144==    by 0x417DB3: lwgeom_from_ewkt (lwgeom.c:736)
> ==32144==    by 0x40A02F: test_mindistance2d_tolerance (cu_measures.c:35)
> ==32144==    by 0x50B32A9: ??? (in /usr/lib/libcunit.so.1.0.1)
> ==32144==    by 0x50B3ACE: CU_run_test (in /usr/lib/libcunit.so.1.0.1)
> ==32144==    by 0x411B6B: main (cu_tester.c:138)
You're in the old parser (parse_it is called) so it's Not My Problem.
Which isn't to say that my parser won't leak, I am, frankly, being a
little lazy knowing that palloc/pfree are going to be behind me
cleaning up the mess.
P.
> and the test then looked like this:
> static void test_mindistance2d_tolerance(void)
> LWGEOM *lw1;
> lw1 = lwgeom_from_ewkt("LINESTRING(0 0, 1 1)", PARSER_CHECK_NONE);
> lwgeom_free(lw1);
> As I understand it we never free *serialized_lwgeom in LWGEOM_PARSER_RESULT
> and I think it should be done in lwgeom_from_ewkt after the result are
> deserialized
> in the structure LWGEOM_PARSER_RESULT there is also room for a pointer to
> the LWGEOM version of the geometry, do we use that?
That's brand new for my parser, which will generate LWGEOM from WKT
instead of generating serialized forms.
> I have only tested those things above on trunk r6120 so maybe the parser
> rewriting is affecting.
Parser re-writing is causing structures and API to be less than
consistent. In general the 2.0 pass is hoping to clean up a great deal
of this so it's a little less full of historical cruft and more
sensible.
One major point is to remove all the functions that generate or work
against serialized form. All API functions (except for two, serialize
and deserialize) should work against LWGEOM structs. This will allow
me to (finally, in the very very end) change the serialized form
underneath the data base to GSERIALIZED.
Sorry, this is a confusing time to be trying to learn from the API. Be strong.
Paul
> I am glad for any hint to help me understand.
> Thanks
> Nicklas
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
