[postgis-devel] [PostGIS] #648: ST_Summary starts and ends with a newline
PostGIS trac at osgeo.org
Sun Oct 24 18:21:58 PDT 2010
 Reporter:  mwtoews  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
 Pick your favourite geometry, pass it to ST_Summary and it will both begin
 ''and'' end with {{{\n}}} newline characters.
 #!sql
 select st_summary(geometry), regexp_replace(st_summary(geometry), E'\\n',
 E'\\\\n', 'g')
 from (
   select 'SRID=4326;POINT EMPTY'::geometry
   union all select 'MULTIPOLYGON(((0 0 0, 0 1 1, 1 0 2, 0 0 0)), ((10 10
 2, 12 10 4, 12 12 3, 10 10 2)))'::geometry
   union all select 'SRID=4326;LINESTRING(0 0 0 0, 1 1 1 1)'::geometry) as
 foo;
 If you use pgAdminIII, you incorrectly see blank lines from ST_Summary,
 unless you expand the row heights from the default to revel the
 multitiline output where text begins on the second line.
 The output from multiline PostgreSQL functions (e.g., {{{select
 table_to_xml('geometry_columns', true, true, 'foo');}}}) does not have
 this behaviour. Newlines should only appear within the text body, and not
 on the ends.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/648>
