[postgis-devel] [PostGIS] #652: ST_IsValid and adjacent polygons
trac at osgeo.org
Wed Oct 27 01:54:13 PDT 2010
Reporter: gaosgeo | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: ST_IsValid, Self-Intersections |
It seems that ST_IsValid (and thus ST_IsValidReason) throws errors
inconsequently. See following examples (both 2D and 3D):
A) 2D: These two polygons are adjacent in (0 1) and (1 1)
SELECT ST_isvalidreason(ST_GeomFromEWKT('MULTIPOLYGON(
((0 0, 1 0, 1 1, 0 1, 0 0)),
((0 1, 1 1, 1 2, 0 2, 0 1)))'));
==> Self-intersection[0 1]
Shifting one vertex to (0 0.9), no other error is thrown. What about Self-
Intersection in (1 1) then?.
SELECT ST_IsValidReason(ST_GeomFromEWKT('MULTIPOLYGON(
((0 0, 1 0, 1 1, 0 0.9, 0 0)),
==> Valid Geometry
B) 3D: Same errors with same polygons, but lying at different z-values.
SELECT ST_isvalidreason(ST_Geometryfromtext('MULTIPOLYGON(
((0 0 0, 1 0 0, 1 1 0, 0 1 0, 0 0 0)),
((0 1 1, 1 1 1, 1 2 1, 0 2 1, 0 1 1)))'));
==> Self-intersection[0 1 0.5]
Any hints?
I'm using:
- POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August
2008" LIBXML="2.7.6" USE_STATS
- PostgreSQL 8.4.4, compiled by Visual C++ build 1400, 32-bit on Windows 7
64-bit
I attach a short file with the given examples.
Thank you and best Regards,
ga
Ticket URL: <http://trac.osgeo.org/postgis/ticket/652>
