[postgis-devel] [PostGIS] #622: [raster] raster2pgsql.py -d option deon not actually drop the table
trac at osgeo.org
Wed Oct 27 06:14:13 PDT 2010
Reporter: pracine | Owner: mloskot
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by jorgearevalo):
Actually, the -d option is not working for me. If you specify "-d" as
option, an error is raised with the text: "options -c and -d are mutually
exclusive"
It's normal, because "-c" is the default option and is always true. If you
specify "-d" option, "-c" must be false. I need to fix this (only a
reminder)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/622#comment:1>
