[postgis-devel] [PostGIS] #653: raster install packaging - change version and install rtpostgis.sql in postgis-20
trac at osgeo.org
Wed Oct 27 20:01:50 PDT 2010
postgis-20
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
I see 2 lurking issues
1) Can we have the below return 2.0.0SVN to match with the dll/so name.
Its bit confusing since we have an older wktraster and we now have a
versioned dll.
SELECT postgis_raster_lib_build_date(), postgis_raster_lib_version();
postgis_raster_lib_build_date | postgis_raster_lib_version
2010-10-27 18:19:50 | 0.1.6d
2) The rtpostgis.sql is being installed in a rtpostgis-20 folder. It
should be installed in postgis-20 I think since we consider it part of the
same component.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/653>
