[postgis-devel] [PostGIS] #1115: Numerical problem in ST_Polygonize
PostGIS trac at osgeo.org
Thu Oct 14 11:08:11 PDT 2010
 Reporter:  gabrimonfa  |       Owner:  strk
     Type:  defect      |      Status:  assigned
 Priority:  medium      |   Milestone:
Component:  postgis     |     Version:  1.5.X
 Keywords:              |
Comment(by strk):
 Basically one of the components being polygonized has a very small segment
 near the node. This makes GEOS (and probably also JTS) confused about the
 order in which edges get out from a node, so which way is clockwise and
 which counterclockwise...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1115#comment:4>
