[postgis-devel] Geocoder geometry_columns
Paragon Corporation
lr at pcorp.us
Thu Oct 14 15:44:29 PDT 2010
No it doesn't. Never rally had a need for it showing as far as geocoding is
concerned.
It does have the constraints in place for each table since constraints are
inherited, so in PostGIS 2.0 I do see them in geometry_columns since in 2.0
geometry_columns is just a view that reads constraints or typmod.
I don't want to insert into geometry_columns because that would break
PostGIS 2.0.
You'd be safer running populate_geometry_columns() since that would work
for both PostGIS 1.5 and be ignored for tables that already have constraints
or typmod in 2.0.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
maplabs at light42.com
Sent: Thursday, July 14, 2011 3:51 PM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] Geocoder geometry_columns
does the geocoder db have geometry_columns entries after it is built?
It was late at night and I wrote this.. could be useful
import psycopg2
all_pre = [
'al','ar','az',
'ca','co','ct',
'dc', 'de', 'fl', 'ga',
'ia', 'id', 'il', 'in',
'ks', 'ky', 'la', 'ma',
'md', 'me', 'mi', 'mn', 'mo', 'ms',
'mt', 'nc', 'nd', 'ne', 'nh', 'nj',
'nm', 'nv', 'oh', 'ok', 'or', 'pa',
'ri', 'sc', 'sd', 'tn', 'tx',
'ut', 'va', 'vt', 'wa', 'wi', 'wv', 'wy'
all_tbls = {
'_place' : 'MULTIPOLYGON',
'_faces' : 'MULTIPOLYGON',
'_edges' : 'MULTILINESTRING',
'_cousub' : 'MULTIPOLYGON',
'_county' : 'MULTIPOLYGON'
conn = psycopg2.connect("dbname=geocoder")
curs = conn.cursor()
for tPre in all_pre:
for tTble in all_tbls.keys():
tSQL = '''
INSERT INTO geometry_columns VALUES ('', 'tiger_data', '%s', 'the_geom', 2,
4326, '%s');
''' % ( tPre + tTble, all_tbls[ tTble ] )
curs.execute( tSQL )
conn.commit()
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
