[postgis-devel] [PostGIS] #1118: Street pretypes that aren't directional prefixes
trac at osgeo.org
Thu Oct 14 23:50:19 PDT 2010
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: 1.5.X
Keywords: |
Old description:
> Example:
> Camino del Rio is an example as noted in:
> http://www.postgis.org/pipermail/postgis-users/2011-July/030152.html
> normalize_address doesn't handle these at all and tiger data is
> inconsistent as to how it represents these.
> So for example:
> In tiger: Camino del Rio is represented as having
> fullname:
> Cam del Rio
> name:
> del Rio
> and pretypabrv:
> Cam
> But in other locations of the world you'll see it listed as
> fullname:
> Cam del Rio
> no pretyabrv
> The two wasy to handle this would be to introduce a new:
> norm_addy object -- the pretypabbrv
> and another table to store these lookup alternative spellings
> and changing geocode to handle this new field and changing the
> normalize_address as well.
> OR (2) which I am leaning toward.
> have a pretypeabbrv lookup and just during the geocode process,
> compare tiger street names against all normalized street name forms (e.g.
> basically replacing any of these if they start at the beginning of the
> streetname with the abbreviated form and comparing with the
> normalize_address.
> Option 2 seems much easier to implement and will also handle many cases
> such as the case of St. vs. Saint.
New description:
Example:
So for example:
fullname:
Cam del Rio
name:
del Rio
and pretypabrv:
Cam
fullname:
Cam del Rio
no pretyabrv
normalize_address.
Example to test:
So now:
SELECT pprint_addy(addy), ST_AsText(geomout), rating
FROM geocode('477 Camino del Rio South, San Diego, CA 94115');
Comment(by robe):
actually highways are on this list so I have partially taken care of this
in r7641 by gluing this on to front. Solution for things like Camino
probably easiest to mark them as highways. Only issue I have now is that
if I add Camino to list of street types as and mark as a highway, my
normalize cuts of the Rio. This is yet another bug in the normalizer
which I have to address.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1118#comment:1>
