[postgis-devel] [PostGIS] #1077: Regression tests for tiger geocoder
trac at osgeo.org
Fri Oct 15 03:52:48 PDT 2010
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: high | Milestone: PostGIS Future
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by robe):
Okay we have a good chunk of failures, fixes and regress example takes due
in great part to Mike Pease and others. These have been added already to
folder regress and tests in there normalize_regress.sql,
geocode_regress.sql as well as the expected outputs after fix in
normalize_regress, geocode_regress.
Brian Hamlin has provided more normalize failures based on USPS cass test
suite. These we should add and tackle first the ones that prevent
accurate geocoding. Below is list exerted from postgis-devel. Some of
these failures are not surprising and some are even relatively harmless as
far as geocoding is concerned but their behavior should be fixed and/or
noted in the regress tests.
400 AVENUE I, WEST POINT, GA 31833
400 AVENUE I W, POINT, GA 31833
19596 COUNTY ROAD 480, COLCORD, OK 74338
19596 480 Co Rd, COLCORD, OK 74338
29779 STATE HIGHWAY C BOX 974, POTOSI, MO 63664
29779 C State Hwy, POTOSI, MO 63664
10559 NE STATE HIGHWAY 90, PINEVILLE, MO 64856
10559 90 State Hwy NE, PINEVILLE, MO 64856
18208 N COUNTY ROAD 241, ALACHUA, FL 32615
18208 241 Co Rd N, ALACHUA, FL 32615
4345 ROUTE 353, SALAMANCA, NY 14779
4345 353 Rte, SALAMANCA, NY 14779
19799 STATE ROUTE O, COSBY, MO 64436
19799 O State Rte, COSBY, MO 64436
1292 NE AVENUE B, SWEETWATER, TX 79556
1292 NE Ave, SWEETWATER, TX 79556
399 WEST AVE F, JEROME, ID 83338
399 WEST Ave, JEROME, ID 83338
19126-20 9TH AVE, PARKER, AZ 85344
1912620 9TH Ave, PARKER, AZ 85344
1818-307 N 40TH ST, PHOENIX, AZ 85008
1818307 N 40TH St, PHOENIX, AZ 85008
4D 664TH ST, NEW CASTLE, AL 35119
4 664TH St, NEW CASTLE, AL 35119
110 CENTER COVE I, SPICEWOOD, TX 78669
110 CENTER Cv, SPICEWOOD, TX 78669
492 STUYVESANT AVE # 4223 # 1330, IRVINGTON, NJ 07111
492 STUYVESANT Ave, IRVINGTON, NJ 07111
114 HAYES ML RD APT B122, ATCO, NJ 08004
114 HAYES ML Rd, APT, ATCO, NJ 08004
4906 LA BR APT A, HOUSTON, TX 77004
4906 LA Br, APT, HOUSTON, TX 77004
900 CITY FEDERAL BUILDING # 407, BIRMINGHAM, AL 35203
900, BUILDING # 407, BIRMINGHAM, AL 35203
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1077#comment:6>
