[postgis-devel] [PostGIS] #886: Fix normalizing of multi street number range addresses and fractional street numbers
PostGIS trac at osgeo.org
Fri Oct 15 04:01:04 PDT 2010
street numbers
 Reporter:  robe            |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS Future
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 A number of the errors noted in #1077 of Brian's list are street number
 normalization which is not quite yet feasible to fix without augmenting
 norm_addy structure.
 My inclination is to just add an extra field called address_extra so that
 the current address field (which is badly named since it's really street
 number), would contain the first numeric segment of a street and
 address_extra would be a text field that would contain the rest of the
 street number.  This would solve street ranges, alpha numeric street
 issue, and most fractional street cases.  The pprint_addy would then be
 revised to take this new address_extra into consideration when formulating
 the display.
 So for example:
 19126-20 =>  address: 19126  address_extra: -20
 4D => address: 4, address_extra: D
 123 1/2 => adress: 123, address_extra: 1/2
 For geocoding we'll just ignore the address_extra part since in most
 cases, they don't add any benefit to geocoding.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/886#comment:3>
