[postgis-devel] [PostGIS] #1125: pprint_addy fix display of highways, routes and other pretyabbrev
PostGIS trac at osgeo.org
Fri Oct 15 21:15:54 PDT 2010
  Reporter:  robe            |       Owner:  robe
      Type:  defect          |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  tiger geocoder  |     Version:  1.5.X
Resolution:  fixed           |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Took the lazy way for now -- fixed at r7646, also got revised geocode to
 put the pretypabrv in streettype field for now since pprint_addy now
 correctly picks it up.
 Added some of Brian's cass examples from #1077.  Brian -- if you are
 listening -- I wasn't absolutely sure the output CASS was expecting for
 these but assumed these are right.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1125#comment:1>
