[postgis-devel] [PostGIS] #1131: Make geocoder faster
trac at osgeo.org
Tue Oct 19 06:46:31 PDT 2010
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: 1.5.X
Keywords: |
I'm working on making the geocoder faster.
I have the reverse_geocoder pretty fast (used to take a second or 2 for
each, but now have that down to 20-40 ms)
mostly by correcting the edges tlid (which was numeric making bigint like
the others) and getting rid of use of addr.
However this somehow screwed up the speed of the regular geocoder at least
on my windows db. I'm almost done reworking. I've decided to get rid of
the use of addr altogether and the speed seems much better but I have to
fix some regress failures resulting mostly from my mistyping of left and
right.
The data in addr is in most cases (if not all for roads) redundant with
what is already in edges. I think in 2008 the lfrom/toadd fields in edges
were blank which I think was the main reason why addr was used. In 2010
they are filled in.
If we have more than 2 addr records per tlid the interpolate would be
screwed up anyway the way its computed right now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1131>
