[postgis-devel] [PostGIS] #576: 3d distance functions
PostGIS trac at osgeo.org
Mon Sep 6 02:32:44 PDT 2010
 Reporter:  nicklas      |       Owner:  nicklas
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by havatv):
 Replying to [comment:9 robe]:
 > Thanks.  I guess we should follow the standard as much as we can even
 though I don't like that aocnvention very much.  So does that mean all our
 functions should be like
 > ST_3DInterects, ST_3DDistance (instead of ST_Distance3D) ?
 Since these new functions are not (yet) SQL/MM Spatial functions, I think
 it would be better to avoid using names that we expect could be used in
 SQL/MM Spatial in the future.  This way we won't have future problems with
 different parameters or different sequences of parameters in PostGIS and
 SQL/MM spatial functions with the same name.
 I am also still against using the ST_ prefix for functions that are not
 included in SQL/MM Spatial - it is an unnecessary source of confusion.
 ST_ should be reserved for SQL/MM Spatial functions, and we should find
 another prefix for PostGIS functions.  But this is probably a lost
 fight... ;-)
 HÃ¥vard Tveite
Ticket URL: <http://trac.osgeo.org/postgis/ticket/576#comment:19>
