[postgis-devel] [PostGIS] #554: Align internal shapelib with official shapelib
trac at osgeo.org
Fri Sep 10 07:01:39 PDT 2010
Reporter: hopfgartner | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by pramsey):
Right, we aim to have code that emits no warnings at all. I had a look and
consulting Frank Warmerdam on this and he pointed out that the dbfopen.c
file you have included does not seem to match correctly to the safileio.c
mechanisms. That is, calls to fseek(), fread(), etc, in dbfopen.c should
actually be calls to psHooks->FSeek(), etc. Your shpopen.c files *does*
seem to use the hooks mechanisms, so it seems like you are using an old
dbfopen.c and a new shpopen.c file. Could you take another run at this?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/554#comment:2>
