[postgis-devel] [PostGIS] #532: Temporary table geography columns appear in other's sessions
PostGIS trac at osgeo.org
Fri Sep 10 08:00:36 PDT 2010
 Reporter:  mwtoews  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 1.5.2
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by pramsey):
 Nevermind, pg_rel_is_visible() won't pick up tables that you are allowed
 to see, but that aren't currently in your search path. We need a better
 patch. I also confirmed that relistemp is a 8.4-only attribute of
 pg_class. So, currently not seeing a solution to the problem, will
 continue to look.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/532#comment:7>
